Advanced CAN Frame to Channel Conversion Reference Example
Hi!
I wonder if any of you guys can help me converting this example into LV7.1.
The example is under:
http://zone.ni.com/devzone/cda/epd/p/id/5826
Thanks in advance!!!
Ogulcan
(3,692 Views)
Accepted by topic author Ogulcan
Ogulcan,
The example that you are asking for is built with a different version of the NI-RIO and Real-Time drivers.  Downgrading this example would require a system with LabVIEW 8.5 or 8.6 with the most current RIO and Real-Time drivers, and a system with LabVIEW 8.0 and an older version of the RIO and Real-Time driver.  It may also require a third system set up up LabVIEW 7.1 and even older versions of the RIO and Real-Time drivers.  The changes in these drivers and the included VI's since LabVIEW 7.1 would also likely make this example not work with LabVIEW 7.1, which may be why it was posted for LabVIEW 8.5.
Eric K
Applications Engineering
(3,664 Views)
Eric,
Thank you very much for the clarification, i really appreciate it.
Ogulcan
(3,654 Views)
