Advanced file manipulation - *.sdf
I am wondering if anyone else has attempted to tackle Hewlett-Packard's
preferred Standard Data Format (.sdf) files with Labview?
I am working an application right now that requires HP instrumentation. I
would like to use Labview to batch process the data files. HP's software is
severly lacking in that it only handles 1 file at a time, and it is msdos
based at that. HP has no intention of writing .dlls for win95, 98 or NT
interface.
The file structure is extensive, with more header fields than data. A lot
of the header info is useless.
If anyone has any ideas, I would most certainly appreciate it.
Thanx
Reply to group.
(3,190 Views)
i have the same problem, viewdata is a soft solution, if you have a solution, please report me, i am searching a solution, when i get it i put it in the group.
(3,190 Views)
