Advanced formula parsing and arrays
I'd like to eval formulas with an array input, such as
y = x[i] + x[j] .....
This can be done normally with a Formula Node when the formula is static, but how about when the formula itself is an unknown string? None of the Advanced Formula Parsing VIs seems to fit.
(3,413 Views)
Your question is too general. You should give an example of what you want to accomplish.
Chilly Charly    (aka CC)
(3,397 Views)
The question is way too generic to ba able to create a specific example.
I believe you could look at the example that is found in the following folder
labview\examples\math\math.llb\Behavior of Modified Function Graph.vi
which uses the formula parsing from string function.
AlessioD
(3,392 Views)
INPUTS:
  • a C-like formula with an array argument of unknown size, y = f( x[ ] )
  • an array of doubles of unknown size, x[ ]
OUTPUT:
  • the result of the formula, y
EXAMPLE:
Input Formula (sums the elements of an array):
y=0;
int i;
for (i=0; i<N; i++)
    y += x[i];
Input Array (size N=3):
x = { 3, 4, 5 }
Output:
y = 12
(3,383 Views)
I don't think Formula vis (such as the  Parse Formula String vi) accept loop operators, although the formula node does.
In LV 8.0, you can use a MathScript Node, which uses a syntax similar to MathLab.
(3,374 Views)
