Advanced micro system
has anyone ever worked with a stepper motor controller from AMS (Advanced micro system).
in particular the model DCB 261
thanks
(3,167 Views)
Are you trying to communicate with the controller through serial port???
CLD Using LabVIEW since 2013
(3,127 Views)
yes by the RJ45 port.
I need an RJ45 DB09 converter ?
(3,114 Views)
Your AMS device using "ordinary" RS-232 communications, typically done through a DB9 connector (with 9 pins), but they are using RJ45 connectors (with 8 pins).  Assuming your PC has a Serial Out port that uses a DB9, or you have purchased a USB-to-RS232 converter so you can utilizes one of your USB ports as though it were a Serial Device, all you have to do is create the cable that wires the 8 pins from an RJ45 plug to the corresponding 9 pins of a DB9 plug.  It wouldn't surprise me if AMS, in fact, provides this cable along with their hardware -- their Manual seems to suggest this.
Bob Schor
(3,103 Views)
