Advice for real performance of LV8.5 operate in the XP and Vista
Hi all
My company had purchased new computers for LabVIEW programming purpose.
We may install the LV8.5 in these computers but OS are not decided yet. Also, we have the current PC is only XP licensed
Therefore, can anyone give the advice for the real performance advantage of using :
LV8.5 with Vista over LV8.5 with XP
LV8.5 with Vista over LV7.1 with XP
LV7.1 with Vista over LV7.1 with XP
New computers detail:
Intel(R) Pentium(R)Dual-Core processor E2160
BCH-P111 -1.80GHz, 1MB L2 cache, 800MHz FSB
2GB RAM
Best Regards
Steve So
(3,504 Views)
The biggest issue I have seen with 8.5 Vista vs. XP is that if you leave Vista in the standard theme, the fonts have changed.  I designed several front panels to have them be out of whack with XP.  So if you are going to be using code across platforms, you need to keep in mind they will look different unless you use the XP theme in Vista, or customize your fonts to make sure they remain the same between the systems.  The dialog font is a different size (13 on Vista vs. 11 on XP), and a different font (can't remember the difference).  That was the big one I noticed.
8.5 over 7.1 is mostly going to be the learning curve to learn the new features.  Overall, I have appreciated the changes, but there are some things (mostly development related) that I have seen run a little slower in 8.5 than in 7.1, but have not noticed any runtime issues as of yet.  One big change between the versions is application building, which is more complex in 8+.  I do appreciate the new features, though, but NIs project still hasn't rubbed me the right way yet.
NI doesn't support LV 7.1 with Vista.  I have used it and haven't seen any problems, but that doesn't mean one won't pop up.  If you're going to stay with 7.1, you better stay with XP.  8.5 is the first version NIs supports as Vista compatible.  You will also have to use a relatively new set of device drivers, so if you have old hardware you are trying to use in your new system, make sure it is cimpatible with the latest drivers.
I have actually had more issues with other hardware drivers and software packages than I have with LabVIEW.  TestStand is not yet supported in Vista, and i found out the hard way, one of the ways it is incompatible and had to move back to XP for devlopment.
(3,485 Views)
I am trying to install NI-DAQ for NI 9233 but it does not work. I have labview 8.0 and windows Vista. Labview 8 works good until now in this windows, so the problem is with windows, with labview?. I can not install the software NI-DAQ 8.5 or 8.6 because  appear this message:
Unsupported version of National Instruments system component detected
Unsupported version of NI-VISA detected
Unsupported version of NI PXI Platform Services detected
Unsupported version of NI-DAQmx detected
Does anybody know what can I do???????????????
(3,461 Views)
See reply to Rafo's question here.
Tom W
(3,434 Views)
Thanks for Matthew.
I also heard that someone can work with LV7.1 in Vista. From their view, they said that it is still work fine in Vista (only programming aspect). They hadn't mentioned that what is the performance for communicating with the hardware by LV7.1 in Vista.
Best Regards
Steve So
(3,416 Views)
