Advice on 1st FPGA project (if your bored)
Hi guys--
Just finished the FPGA portion of my first cRIO project, and am throwing it out here in case anyone has any pointers.
"Laser Stabilization (FPGA).vi" is meant to use C-Series AI and AO ports to implement a phase sensitive detection scheme ("Signal Simulation.vi", in the folder named the same, illustrates the overall method), with a PID control loop at the end.
It's all fairly small and contained.  I haven't completed the host portion of the project yet, so none of that is included.
I'm sure I have plenty to learn still, so any casual advice is appreciated.
Thanks all, and have a great day.
(2,481 Views)
You can have cRIO related documentation on ni.com. You will find plenty of examples also. You just need to search on ni.com
PBP
Labview 6.1 - 2019
(2,467 Views)
