Advice on breaking up Stacked Sequences in 6.1?
I've dived right into an old but functional test system ~300 VI's. Flow and structure is pretty hard to follow and I'm thinking of breaking it up into state machines.
Any ideas on how to approach a stacked sequence beast in 6.1? Flat sequence seems crucial to the method described here.
Rough layout of main vi attached:
(2,703 Views)
Open your VI in LV 8.x and use the method described in your linked thread 😉
You can copy the sequence and remove it while displaying frame 0 in the original and frame 1 in the copy. If you have controls/indicators they will be duplicated. Also, wire connections via sequence locals will be lost. So you will have to rewire and clean up your code. But I think there's no straightforward solution because flat sequences didn't exist in 6.1.
(2,700 Views)
