Aerotech u500 CIN programming
I am wondering if there is a user of Aerotech in this board.
I want to use one of U500 WAPI libary, AERERR_CODE  WAPIGetDiag (ULONG  *statword , SHORT debugflag).
In call library function dialog in Labview 7.0, I set up "unsigned long WAPIGetDiag(unsigned long *statword, unsigned short int debugflag)".
Am I right?
However, how to use the value of the pointer, *statword?
The return statword is the same value as the input value.
Thank you in advaned.
Attachment: user.vi (LV7.0)
(3,432 Views)
Hi labmaster,
You'll want to select "Pointer to value" in the call library function dialog, as shown:
Message Edited by SamboNI on 04-25-2007 03:46 PM
-Sam F, DAQ Marketing Manager
(3,414 Views)
