Affecting Component of Cluster in Different VI
Within my Project I have 2-VIs (One.vi and Two.vi) that have the same Cluster, containing a String and Numeric. I also have a Global with the same Cluster
I would like to cause an event in One.vi by changing the value of one component in Two.vi
i.e. if I change the Numeric in Two.vi, I expect the Numeric Event in One.vi to occur
Similarly, if I change the String in Two.vi I expect the String Event in One.vi to occur
That is not happening in my example
Please see the attached files.
They are in a single project
Keith
(1,361 Views)
One.vi doesn't capture ant events.  Changing values of the cluster in One.vi has no effect because there is no code in One.vi that does anything with changes in the cluster.
(1,353 Views)
Actually, the Event in the Cluster.String Value Changed... always occurs in One.VI
(1,331 Views)
No. When you change the cluster in 2, the event fires, and makes the change in the cluster in #1 via the control reference point to the cluster in #1 that you saved in the global.
There is no code in 1.vi to detect when the cluster in 1.vi changes, and no mechanism to send that data to 2.vi to change the cluster there.
If you want to send messages or data between VI's, you should be using a queue to send data from 1 to 2.  And a second queue to send data from 2 to 1.  That or register for user events.
Actually register for a user event in 2.vi based on a value change on the cluster in 1.vi is probably the correct way to do this, but I rarely have a need for user events in the code I'm working with, so I'm not going to be able to state that for a fact or be able to suggest an example to demonstrate it.
(1,295 Views)
