After I remove the Block Diagram, The VI under RT target is always broken.
Why the VI is always broken under RT target if I remove their BD?
My LabVIEW Version is 2012 f1. I remerber that I have done a lot of remove in the last year and works well on RT. Really don't know why it's not work this time. Even for a very simple diagram...无标题.png
(2,706 Views)
I removed it's BD and put it under a PXI Real-time target. It says:
"This VI has a bad connection to or cannot find a subVI or external routine but it has no block diagram to show or fix the error. You must find or correct the subVI or external routine. Check for more information in the Explain dialog box in Get Info."
(2,703 Views)
If I set it as Non-reentrant. It'll not be broken... does anyone knows why?
(2,699 Views)
Why did you remove the block diagram?
(2,679 Views)
