After build exe file . the config.ini file change the path
i have config.ini in my proj
after build exe file i get that error
Error 7 occurred at Open VI Reference in Open Config.vi->Start Main.vi.
VI Path: C:\IRP Burn SW\Labview Proj\EXE Build\SWDL.exe\IRP Burn SW\Labview Proj\configuration.vi
in my proj configuration file locat in : C:\IRP Burn SW\Labview Proj\Config File\config.ini
how can i solved this problem ?
(4,174 Views)
Thanks, solved
(4,094 Views)
