After building executable file, it runs abnormally with no startup VIs.
I'm programming in Labview 8.0.1.
I just modified some place in a big project, which is, adding a new subVI and it will be called when a button is pressed. But after my re-build this project, this subVI will start along with the main VI when the program starts. And also there exist some errors during execution.
I found that all vis and subvis are gathered in one LLB file. I didn't add my new subvi to this file. Does it matter? or is there some other problems about my modification? I am really confused for this for a whole afternoon. Hope someone can help me.
Thank you in advance.
Han Zhao
(2,350 Views)
Hi Han Zhao,
You mentioned an error - is there some error-message or an error-code?
grroesis
(2,273 Views)
