After install LabVIEW 8.6, some of my programs can't be loaded.
The error is:
LabVIEW 8.6 development system has encountered a problem and needs to close.  We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Anyone has experienced the similar problems?  Is that because of the bugs of 8.6?
Thanks.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
Message 1 of 14
(3,887 Views)
Could you provide a bit more details on what your programs do. Anything unique and exotic? Any toolkits and add-ons?
Did you reboot after installations when asked?
Message 2 of 14
(3,884 Views)
Hi Weiyuan,
til now, i don´t see this behavior. Can you explain what you make in your programs where this error occured?
Mike
Message 3 of 14
(3,883 Views)
Do you know something we don't? Smiley Happy
Message 4 of 14
(3,874 Views)
Looking at the LabVIEW 8.6 Known Issues document, I cannot see anything obvious.
Message 5 of 14
(3,869 Views)
It is an acquisition program to acquire an image from a camera through the acquisition board.  It uses ni-vision.
The backup program from long ago can be opened by 8.5 and 8.6, but after I saved, the backup program can't be opened by 8.6.
Message 6 of 14
(3,849 Views)
Which version of NI-Vision? Have you updated NI-Vision to be compatible with 8.6?
I'm assuming you still have the backup in 8.5 and you didn't overwrite it when you said you saved it in 8.6.
Message 7 of 14
(3,844 Views)
Thanks.  The vision is 8.6 too.  When "save all" the backup becomes 8.6 too.  We gonna contact NI see what they say.
Message 8 of 14
(3,796 Views)
Weiyuan,
Can you post your code? Also, have you called and spoke to an Applications Engineer yet? What kind of Vision functions are you using?
--Michelle
Message 9 of 14
(3,776 Views)
Thanks a lot.  My classmate called the applications engineers, they can't open the vi, but they said they gonna investigate it.  It uses, IMAQ create, set image size, readfile, histogram, roitomask, etc.  The problem is when double click the vi, the error will come out, can't even see the block diagram or front panel, how to investigate from that?
Message 10 of 14
(3,733 Views)
