After loading 24-bit depth image max pixel value is 255
Here is a small example where 24-bit depth image is loaded as Grayscale 16-bit.
The maximum pixel value is 255, but not 65535.
Loading as Grayscale (SGL), i.e. float, 32bit produce the same result.
2 questions:
  • is there a workaround allowing to load 24-depth image as 16-bit
  • is there some option in "google image search" allowing to find 16-bit images
(8,060 Views)
Hi Pavel,
is this a "standard" JPEG you try to load? A JPEG with just 8bit color information?
When there is only information of 8 bit color entries you can not magically blow them up to U16 or SGL values…
(8,049 Views)
Hi GerdW
Here is file properties of the image that I've found with Google (specifying BW option).
If I properly understood your comment, for BW jpeg images only 8 bits are significant?
If it's the case, my 2nd question is probably more relevant, i.e. how find true 16-bit depth BW image on web without having to download each image and check its properties.
(8,041 Views)
Accepted by topic author Pavel_47
Hi Pavel,
24bit = 3×8bit (RGB)…
I would search for "16 bit grayscale images". And I would use other image formats like PNG or TIFF instead of JPG…
(8,035 Views)
Ok, thanks
(8,029 Views)
