After the install I can't find the Run Time
Accepted by topic author ahhah
In your original post, you said you generated an executable with the installer. The installer does not create an exe. In the build specifications, you have to first select 'Application (EXE)'. After running that, then you use the installer and select the exe you just created.
Message 11 of 16
(3,222 Views)
Spoiler
If this is a
If this is a two step process--making an application for pc which doesn't have LV installed--that explains my problem.  I was fooled into thinking my process worked when I installed it on machines that already had LV installed.
Message 12 of 16
(3,219 Views)
You are correct, it is a two step process.  You can only use an application (.exe) on systems with the LV development sw already installed, because it has the runtime loaded on it; otherwise, you first create the app, then the installer.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 13 of 16
(3,210 Views)
Thanks!!!
Message 14 of 16
(3,204 Views)
You really should not mark your thanks as the solution. The idea of marking the actual solution is so someone can quickly go there without scolling through a long thread. You can change this by clicking on the 'Options' button.
Message 15 of 16
(3,201 Views)
The file type (.exe) is not supported. Valid file types are: 7z, bld, bmp, c, cap, cfg, chm, cir, cpp, cs, csv, ctl, da, ddd, ddf, digiproj, dll, doc, docx, dot, dotx, dsb, eip, emp, ewprj, flxproj, gbr, gcdl, gcomp, gif, gmrd, grsc, grtm, gpal, gconversion, gtype, gvi, gviweb, gz, h, html, icd, ico, ini, ipk, jpg, jpeg, l4p, l4t, lep, lks, llb, log, lvaddon, lvcompile, lvdd, lvdist, lvlib, lvm, lvproj, lvproject, lvprojx, m, mp4, mp11, ms10, ms11, ms12, ms12, ms13, ms14, ms7, ms8, ms9, msm, nimanifest, nivsprj, nitrace, nipkg, ogp, pdf, png, pps, ppt, pptx, pxiproj, prz, py, rtf, scr, seproj, seq, sli, smuproj, spy, sud, tar, task, tca, tdm, tdms, tdr, tdrm, tdv, tsw, tuc, tui, txt, uir, uri, vascr, vb, vbai, vbs, vhd, vi, vim, vip, vipc, vit, vix, wbassets, wbx, wmv, wsp, xctl, xls, xlsx, xlt, xltx, xsl, xslt, z, zip, sit, llb, rar.
Message 16 of 16
(2,275 Views)
