Agilent 11713 with Labview
I was trying out this Agilent 11713A Attenuator/Swtich Driver with Labview. I was using the NI's example VI and just found out that it was doing the wrong thing after 7dB. I will post it on this thread.
I am using a HP8494H(11dB) attn and a HP8496H attn.
HP8494H att dB:1  2  4  4
HP8496H att dB: 10  20  40  40
I am using both together. Attn X with the 11dB  and Att Y with the 110dB.
Has anyone tried the boolean logic for the Agilent 11713 Attenuator Driver?
(3,884 Views)
Found it.
Did a search under HP11713A and got more info.
(3,883 Views)
Hi rram i am having the same problem you were facing back then. how did figure out to get it work? thanks & appreciated!
(3,637 Views)
Hello what is the problem you are seeing?
(3,620 Views)
