Agilent 33220A (Function Generator) .. To Turn ON DC output
hi ,
Iam using the 33220A ,Agilent function generator ..with labview 8.5 ..
I need the control or Subvi that will output a DC .. i.e on the agilent ..Utility->DC off/On .. i need to activate the DC ON ...with a particular Dc offset voltage ..
Iam unable to find a subvi which can do this ..
Iam currently using the labview driver downloaded from the ni.com.
Anwar.
(3,081 Views)
Have you tried ag33xxx-Config Waveform? One of the waveform shapes available is DC and there is control called Offset.
(3,079 Views)
