Agilent 34461a Times out when I deploy the VI
Hey there,
I am currently developing a program which makes use of an Agilent 34461a. The problem that I am getting is that when I deploy the program (build the installer and install on another machine), the code for the agilent times out.
I have attached a picture of the higher VI, where the Agilent Code is called so you can have a reference of how it works.
I am using the drivers for the Agilent provided by NI, and so I don't think there's any error in that, although I do get the error when I deploy it.
The error code that I get is the following:
-code: 10738973339
VISA Write in Agilent 3446X series.lvlib: Initialize VI.
So we know that the error is happening at the Init VI (which I have also attached a pic), but I can't figure out why. Restating, it works perfectly in development mode but when I deploy it, it doesn't work.
I have also attached the VI pack I am using.
Thank you for your help
(1,236 Views)
Error "10738973339" is an undefined error code. "-1073807339" is a timeout error. Is that what you are getting? If so have you tried any of the steps here - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L3mSAE&l=en-US
(1,195 Views)
