Agilent 34970a Resistance Driver problem
I’m using a Keysight 970a in Agilent 34970a emulator mode which works with Agilent drivers.  I’ve been able to use the EZ Temperature, EZ Voltage, and EZ Resistance drivers successfully, but when I try to set up a basic resistance VI (by initializing, configuring resistance, configuring scan list, configuring scan, and scan), it initially gives me a correct reading on first pass, but after re-triggering, it results in erratic, incorrect readings.
I will note that I was able to get the attached VI to successfully execute when I swapped out Conf Resistance for Conf Temperature and Conf Voltage.  After making those execute reliably, I swapped them back out for Conf Resistance and after first pass, it doesn't give an accurate reading upon re-triggering.  There are no error message when I'm getting an incorrect reading.
Message 1 of 1
(366 Views)
