Agilent 34972A - Using a single channel to read multiple data from a function generator. Example - Using channel 101 to read frequency and ac voltage from a function generator
Hello what should i do ? i am using the Advance scan Example Program
(2,599 Views)
Hi soarin,
right now your example VI should read just one sample from your DMM.
When you need more samples you should repeat the read operation more often: usually you use loops to repeat part of codes…
What exactly do you want to know?
Generic answers on your generic question:
  • How to use your DMM? Then read its manual…
  • How to use LabVIEW? Then take the free beginner tutorials…
(2,572 Views)
Hi Sorry for my post
okay i want to know how to program this advance scan program. To read multiple input data at once on a single channel that is connected to a function generator.
(2,552 Views)
Hi soarin,
Probably there is another example VI showing how to acquire a waveform from your DMM.
Otherwise I already mentioned those beginner tutorials to help you learn LabVIEW!
(2,543 Views)
