Agilent 34980A with flow meter
Hi all ,
I am using a Flow tech Flow meter to measure the refrigerant flow.
I want to know how I can configure Pulse output in Agilent 34980 A containing module 34921A in Labview.
If a choose frequency there is a random frequency even without flow when I am seeing the signal through Agilent Benchlink. How to solve it .
(1,269 Views)
Hello yespee007,
May I know did you have installed an IVI driver?
Which code do you use for controlling them?
Edgar Umrikyan,
Staff Technical Support Engineer
NI
(1,202 Views)
