Agilent 4284A C-T Measurement
Hello, I am new to LabView and would like to develop a program to take C-T (capacitance vs. time) measurements using the Agilent 4284A LCR Meter.  I currently have a LabView program that can take C-V measurements.  I am hoping for any suggestions/ideas on how the Instrument Driver for the 4284A LCR meter can be used to create a new program or modify the exisiting one to take the C-T measurements.  I have contacted Agilent and they informed me that the 4284A LCR meter does not natively support transient measurements, but they can be done by setting up a time base to trigger the measurement.
Chirag
(5,479 Views)
Hi Chirag,
It sounds like you found the instrument driver available for the Agilent 4284A.  In order to use it, you will need to know the command that the instrument needs to set your time base.  All of the VIs in the instrument driver can be modified for use within your own code.  I've included a few helpful tutorials for the process.
How to Use an Instrument Driver in LabVIEW Tutorial
IVI Instrument Driver Tutorials
Meghan
(5,463 Views)
Hi Chirag;
i have a program that can measure the C-T with your machine, however i would like to give me the labview program that measure the C-V
(4,936 Views)
Hi MOFF,
This thread is from 2007. If you think it is nessciary you can contact the original poster through private message. If you have other questions involving the Agilent 4284A then please post in the appropriate form.
Thank you,
Kurt P
Automated Test Software R&D
(4,918 Views)
Hi chirag;
i would like to send me the labview program which measured the C(V) with your machine (Agilent 4284A).it necessary for me to complete my experiment.
thank you;
(4,904 Views)
Hi Moff,
Unfortunately this was part of a course project a few years ago and I nolonger have the data.  I believe I did find some helpful information from other support threads in the forum though.
All the best,
Chirag
(4,891 Views)
Hi moff
I hava a problem in coding a program to control agilent 4284A to measure C vs T. The measure period of my program is about 20ms-70ms. I wonder whether i can reduce the period to 1ms
(4,708 Views)
