Agilent 488.2 with Labview
I have an Agilent 82357B USB GPIB and have been supplied code that uses GPIB read and write functions. I have NI-MAX and Agilent Connection Expert setup correctly. The program does not error but the write and read functions timeout and do not work. I troubleshoot wrote simple code using hte VISA functions and they work. I wrote the same code using the GPIB functions and it does not work and after I run it the code written in VISA no onger works. I know that Agilent replaces the gpib-32.dll with their version that redirects to their code.
My question is, is there anyway to make the LabVIEW GPIB calls work with an Agilent GPIB device and of course GPIB library? I believe the answer is no but I have seen a post where someone said they are doing it. I just want a definite answer before I deliver the bad news.
(3,698 Views)
Accepted by topic author terrill
While there have been some vendors that implemented their GPIB drivers with the same function calls that NI uses (ibwrt, ibrd, etc). I don't believe Agilent has ever done this and I've used Agilent cards since the time they were still Hewlett-Packard. I'd love to see the post where someone said they could use the LabVIEW GPIB functions with an Agilent controller.
So, the answer is no to the best of my knowledge. What you need to do is use VISA. Enable tulip support in NI-MAX and it should work.
(3,688 Views)
Here is the post. It is old and he uses the same steps that are needed for VISA.
http://forums.ni.com/t5/LabVIEW/Agilent-82357a/m-p/277987/highlight/true#M147207
(3,673 Views)
