Agilent 53220A Noise Rejection in Labview
Hi im trying to get teh noise rejection feature in the Agilent 53220A Frequency counter to work when i am using totalize continous. However i cant fing how to program it to be triggereed by labview.
(2,853 Views)
What is Untitled 6 (SubVI).vi in your code?  You didn't attach it so the vi is broken when I try to open it.
It looks like you've go the right idea, from what I can tell that is the correct serial command to trigger the device.
Also, you can install drivers for LabVIEW to use with this device.  From LabVIEW, go to:
Help-->Find Instrument Drivers
Choose Agilent Technologies for Manufacturer, then Type 53220A in the Additional Keywords.  This will install a set of functions into the Functions Palette for this device.  You can find it by right clicking the Block Diagram, the navigating to:
Instrument I/O-->Instr Drivers-->Agilent 532XX Series
From here, in the Configure Subpalette there's a function called Configure Totalize Gate.vi.
Perhaps this will help you
Mason M
(2,825 Views)
i dont see where untitled 6 in the code is. can you be more soecific?
i did try to to look through the subpalettes for the instrument but i can see which ones has the noise rejection settings. Configure totalize gate dowsnt seem to have it
Thank You
(2,801 Views)
I attached an image of the block diagram when I open your code.  What is is the subvi on the left side that is missing?  Did you create it?
Mason M
(2,797 Views)
