Agilent 6030A with 59511A Relay Accessory Drivers
Hi, I'm using an Agilent 6030A power supply with a 59511A relay accessory used to swich polarity. I've been able to install the 6030A drivers, however there isn't any VIs or drivers I can find for wither the 59511A or the 6030A used to send commands to the relay accssory. The Keysight website does not have any drivers for the 59511A unit, can anyone tell me where I can find the VIs used to send commands the 59511A unit?
(3,478 Views)
Hello JForonda
I researched our third party instruments driver network( ni.com/idnet ) but unfortunately, I was unable to find the drivers for the 59511A Polarity Reversal Relay Device.
Usually the companies of these products are responsible for releasing their drivers, therefore the next step I would suggest you to follow, would be to reach to KEYSIGHT Technologies support and ask them if there is such a driver.
As a last resource you could always build your own drivers by following the steps on the below link:
https://www.ni.com/en/support/downloads/instrument-drivers/tools-resources/instrument-driver-guideli...
Kind regards,
Vasileios
Vasileios T
National Instruments UK&Ireland
(3,425 Views)
Accepted by topic author JForonda
The operating manual can be found here on the Keysight website. Pages 31 to 35 have the commands you are looking for. Use VISA Write and VISA Read to send these commands and read back from your equipment.
Ben64
(3,414 Views)
