Agilent E3631A
hello, may I ask is there any Agilent E3631A example where I can use two output channel with different voltage at once in LabVIEW. thanks.
Message 21 of 27
(1,770 Views)
Hi Liyana,
You might want to try the Agilent driver from the Instrument Driver Network. There is an example included that lets you select which channel you are outputting voltage on. You can basically copy and paste the code that does this to control another channel.
Agilent E363X Series Power Supply
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0475216F9FCA5335E0440003BA7CCD...
How Do I Install My Third Party Instrument Drivers?
http://digital.ni.com/public.nsf/allkb/86256F0E001DA9FD86256F0B0057E6E7
Message 22 of 27
(1,736 Views)
Hi Frank,
I have installed Instrument Driver Network & I used the example. I also have copied and paste the code to control another channel. However there are 2 errors showed up (attachment). How can I solve this?
Liyana
Message 23 of 27
(1,701 Views)
Your front panel does not make any sense at all. You should not have a second VISA resource. You should only be copying the function to configure the channel and it should be in-line with the existing function for channel one.
Message 24 of 27
(1,693 Views)
Do you mean I should copied like this? It still shows the same errors
Message 25 of 27
(1,690 Views)
No. That makes no sense either. You copy it into the same single chain. You are trying to do things in parallel and that does not work. You must do things sequentially as the original example doors.
Message 26 of 27
(1,681 Views)
Okay I have change it and it is working now with out any errors.  Thanks Smiley Happy
Message 27 of 27
(1,675 Views)
