Agilent E4440A Display line
i try to set my Display Line at 6.299mW
i follow the manual attached, page 88's command.
It did turn on my Display Line,
But the display line doesnt set to the value i want.
is it i write the command wrong ? :<
help
(1,323 Views)
Manual says that:
" The line has an amplitude value that corresponds to its vertical position relative to the reference level."
Try to set it and check.
BR,
Aniket
(1,317 Views)
Hi Aniket
Appreciate that you replied.
I dont really understand the meaning of the sentence.
Does it mean ,
for example if i want to get display line at 10 mW, and my reference line is 5mW, i need put 15 mW in the command ?
so 15 mW - 5 mW = 10 mW ?😥
Sorry if i understood wrongly, appreciate if you could explain or correct me :<
Intern w 1 month labview experience
(1,285 Views)
Yes, Or Simply set reference to 0
(1,270 Views)
