Agilent E5810
The second screen shot shows what happened if I input "gpib0,5". In short, it doesn't allow me to do that.
Message 11 of 29
(2,848 Views)
This 3rd screen shot shows what happened if I input "gpib0" only. Basically, NI-MAX accepted it and the result is shown in the screen shot I posted last week. It seems NI-MAX has a bug.
Message 12 of 29
(2,847 Views)
Could you just check that you have the NI-VISA Passport for GPIB checked in the VISA Passport Options?
Open MAX and select Tools » NI-VISA » VISA Options
In the VISA Options tab, select Passports under General Settings. Then ensure that theNiVi488.dll - NI-VISA Passport for GPIB is checked
Message 13 of 29
(2,798 Views)
Hi, James,
It is selected. Please see the attachment.
Message 14 of 29
(2,756 Views)
Could you try and add a new device by "GPIB-ENET" instead of "VISA TCP/IP Resourse" right click Devices and Interfaces >> create new... >> select GPIB-ENET and follow the wizard.
Message 15 of 29
(2,682 Views)
Hi, James,
I tried it. But the GPIB-Ethernet Wizard couldn't locate a GPIB-Ethernet device, either with automatically browsing or manually specifying an IP address.
Message 16 of 29
(2,658 Views)
Possibly Agilet VISA is being used as apposed to NI VISA, or vice versa, try experimenting with NI VISA or Aglilets version as the Primary VISA in Conflict Manager within MAX
Could you possibly give me an exact description of your system. Possibly there is a compatibility issue. Have you ever been able to talk to GPIB instruments through your Agilent E5810? Or directly for that matter?
James O'Neill - Applications Engineer - National Instruments
Message 17 of 29
(2,455 Views)
Hi, James,
I used both "NI VISA" and "Agilent VISA" as a primary VISA. One at a time. But neither worked.
My system is set up: an Agilent E5810A LAN/GPIB Gateway is connected to my company's network through a Netgear Ethernet switch. My computer is in the same subnet as E5810A. An Agilent 6812B is connected to E5810A through its GPIB interface. It worked fine until I upgraded NI-MAX to 5.3.3.
Currently, I am able to see and talk to 6812B under "Devices and Interfaces" in NI-MAX as "GPIB0::5::INSTR". Not sure how NI-MAX found it. But I used to be able to see it and talk to it under "Network Devices" as "TCPIP0::10.202.11.241::gpib0,5::INSTR" like the Agilent software does.
James, I think the main point is why NI-MAX doesn't take LAN Device Name: gpib0,5 as it instructs users to do so. It used to be fine. Did you ask NI-MAX software development engineers about this?
Message 18 of 29
(2,441 Views)
@Whitman_Cougar wrote:
Hi, James,
That looks like Windows XP.  I don't think MAX 5.x is compatible with WinXP.
[edit] actually, I'm so confused about compatibility, I don't know if that is true or not.
Bill
CLD
(Mid-Level minion.)
Message 19 of 29
(2,427 Views)
Hi, James,
I think I got confused with LabVIEW compatibility, not Windows compatibility.
Bill
CLD
(Mid-Level minion.)
Message 20 of 29
(2,420 Views)
