08-30-2007 12:37 PM
09-04-2007 08:08 AM
09-04-2007 08:52 AM
Hi Chad,
Usually when this error appears, the operator clicks the continue button, and the program attempts the operation again. This cycle can continue for numerous repitions, or just once. I have not detected any network problems, but communicating with this gateway is the only test & measurement use of the network outside of file operations. Also, this program can operate sometimes for hours without an error.
Jim
09-06-2007 01:36 PM
09-07-2007 06:06 AM
Chad,
I don't know how to get MAX to see a network device. It only shows my GPIB devices. If it is a network issue, how on earth would I verify it? It is VERY intermittent.
Jim
09-10-2007 05:46 PM
09-11-2007 06:26 AM
09-12-2007 04:40 PM
Hey Jim,
It sounds like you have it narrowed down to either a network or hardware problem. Are you hooking the GPIB adapter to a hub or router? Or are you connecting straight to your computer? Also, is it possible to try disabling your firewall?
09-12-2007 07:03 PM
09-13-2007 01:33 PM
