Agilent E7403A - Error 1074135024
Hi guys,
I am trying to configure the start/stop frequency on the Agilent E7403A EMC Analyzer. I encountered this Error code: 1074135024 when i try to run the program. Anybody know how to fix this error? Many thanks.
The error i am getting is as shown below.
(3,047 Views)
@FIONACHEN wrote:
Hi guys,
Find that VI.  Figure out which parameter you entered is incorrect.  I can't tell what the values are in those little rectangular terminals.  Can you?  Maybe you should post the VI instead of a grainy picture.
Bill
CLD
(Mid-Level minion.)
(3,018 Views)
This is my VI.
(3,013 Views)
Hi Fionachen,
While reading the manual and checking your parameters you should also remove those local variables and replace them by wires! (What's their purpose anyway?)
For cleaning up the BD you could remove the sequence frames and set the constants to SI format…
(3,008 Views)
