Agilent E8364B labview initialization vi issue
Greetings,
I wrote a vi to configure and capture the S parameter data from an Agilent E8364B PNA.  My vi only works when the initialization vi is set to reset.  If I try to run the vi without an "instrument reset" (which is what I would like to do)  I get an "Error-1074001424 occured at AGPNA Error Query; instrment reports: +104, "Duplicate measurement name"" message.  This also happens with the example vi, "Agilent PNA Series Create Measurement.vi", which is downoaded with the drivers and attached here.   The error occures after the "Configure Measurement Parameter" vi runs.  Thanks in advance for any insight.
Steve
Message 1 of 1
(3,346 Views)
