Agilent ENA Driver - Custom SCPI Commands
Hi all,
I'm currently trying to perform several functions which there doesn't seem to be a 'VI' for within the Labview Agilent ENA drivers. One of these functions is to disable the warning beeper, however the Agilent ENA manual shows an SCPI command of:
:SYST:BEEP:WARN:STAT
Which enables / disables the warning beeper.
Is there a way I am able to send a custom SCPI command to my Agilent ENA (E5071B)?
Many thanks,
Charlie
(3,142 Views)
I suppose you could do a Google search on LabVIEW SCPI.  It's easier than trying to explain it, and some links about halfway down the screen look promising.
Bill
CLD
(Mid-Level minion.)
(3,123 Views)
