Agilent ESA Series Spectrum Analyzer (E4448A) - Can not initialize.
I have downloaded the drivers for the Agilent ESA series Spectrum Analyzers from NI and I am having trouble just running the initialization VI.
I am currently trying to run the VI called: agesa initialize With Options.vi on Labview 7.0 Express
This is the error I receive:
agesa Initialize With Options.viDriver Status: (Hex 0xBFFF0015) Primary Error: (Hex 0xBFFF0015) Timeout expired before operation completed.
It looks like the Spectrum Analyzer does do a few things (Changes Carrier Frequency to 50 MHz), but it's getting hung up somewhere else.
If I highlight execution, the error comes out of the Call Library Function Node elaboration output in the aforementioned VI.
Here are the settings of the VI I have:
Settings:
id query: true
reset device: false
Option string: Simulate=0,RangCheck=1,QueryInstrStats=2,Cache=1 (The default)
Resource Name: GPIB0::16:INSTR
Any help anyone could provide would be appreciated. Keep in mind, I am fairly new at this. Thanks.
From NI Spy (Numbers 20 and 22 with the ">" are the error lines):
Note: This post can only be 5000 characters, so I have deleted a few of the steps:
7. viWrite (0x001D6008, "*IDN?", 5, NULL)
Process ID: 0x00000388 Thread ID: 0x00000728
Start Time: 09:10:37.822 Call Duration: 00:00:00.000
Status: 0 (VI_SUCCESS)
8. viRead (0x001D6008, "Agilent Technologies,...", 511, 50)
9. viWrite (0x001D6008, ":SYST:OPT?", 10, NULL)
10. viRead (0x001D6008, ""226".", 512, 6)
11. viPrintf (0x001D6008, "%s?")
Start Time: 09:10:37.832 Call Duration: 00:00:00.000
12. Formatted viWrite (0x001D6008, "*IDN?", 5, 5)
13. viRead (0x001D6008, "Agilent Technologies,...", 512, 50)
14. viPrintf (0x001D6008, "*CLS;*ESE 1;*SRE 32")
15. Formatted viWrite (0x001D6008, "*CLS;*ESE 1;*SRE 32", 19, 19)
16. viPrintf (0x001D6008, ":CALC:LLIN:CMOD FIX")
17. Formatted viWrite (0x001D6008, ":CALC:LLIN:CMOD FIX", 19, 19)
18. viPrintf (0x001D6008, ":CALC:MARK:FCO:RES:AUTO %s")
Start Time: 09:10:37.832 Call Duration: 00:00:00.010
19. Formatted viWrite (0x001D6008, ":CALC:MARK:FCO:RES:AU...", 26, 26)
> 20. viQueryf (0x001D6008, "%s?", "%hd")
> Start Time: 09:10:37.842 Call Duration: 00:00:17.085
> Status: 0xBFFF0015 (VI_ERROR_TMO)
21. Formatted viWrite (0x001D6008, ":BAND:RES:AUTO?", 15, 15)
Start Time: 09:10:37.842 Call Duration: 00:00:00.000
> 22. Formatted viRead (0x001D6008, "", 4000, 0)
23. viClose (0x001EC548)
Start Time: 09:10:54.927 Call Duration: 00:00:00.000
24. viStatusDesc (0x00000000, 0xBFFF0015, "Timeout expired before oper...")
Message 1 of 19
(5,734 Views)
Hi Numes
I just tested that vi in Agilent E4446A and it runs fine.
I use Lv7.1 xp and last version of 488.
The only thing that looks souspicious to me is the default query:
QueryInstrStats=2. try ...=1. I got errors if diferente from 0 or 1.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 2 of 19
(5,712 Views)
> Hi Numes
> Cheers
> Alipio
Oops, that was a typo. It is in-fact: QueryInstrStats=1.
I will try to see if it works on 7.0 (not express) and 7.1
Message 3 of 19
(5,709 Views)
Hi again
I was reviewing my docs abotut programming this agilent and found source errors for some vis:
Make sure that pressing " System> config I/O > Config remote lang > Language" the selected one is SCPI.
If another compatibility mode is selected, you will get timeouts for commands not AGESA.
Hope this is the problem...Tell me about that.
Alipio
Message 4 of 19
(5,699 Views)
Well, I don't seem to have that option on the E4448A, here's what i do have:
System -> Config I/O ->
GPIB Address
IP Address
Host name
Subnet Mask
Gateway Address
SCPI LAN
Under System -> Config I/O -> SCPI LAN ->
SCPI Telnet
SCPI Socket
SICL Server
None of the above stuff seems applicable if I am only using GPIB?? I tried modifying some of the options above, didn't seem to help.
Here's some more information in the Error History on the Spectrum Analyzer:
-420, Query UNTERMINATED, &ltErr>
-113, Undefined header, :BAND:&ltErr&gtRES:AUTO?
The above looks like #21, and the error, #22, is right after it. Any idea what that means?
I'm going to try it on another computer... More to come!
Message 5 of 19
(5,693 Views)
Just tried it on Labview 7.1 on a different computer. Same results.
It must be something with the setup of the Spectrum Analyzer. This is frustrating.
I wonder if the Config Remote language option is embedded somewhere else?
Message 6 of 19
(5,688 Views)
Hi
Sometimes, it is a long work to make everything run.
Ok.
Just to be sure, my versions are:
Lv 7.1
Visa 3.1
488.2 ver. 2.3
Ivi cp ver. 2.1.2
Interface: GPIB-USB B
Try another vis to see if they run.
Tomorrow, I will make some more tests...Will let you know.
cheers
Alipio
Message 7 of 19
(5,684 Views)
Wow!
Figured it out:
I was in the Phase Noise Mode! When I switched it to Spectrum Analysis Mode it started talking fine. I could have sworn I have tried to power on and power off, it must have stayed in Phase Noise Mode.
Wow. That only cost me I day. I suppose I should be fortunate 🙂
Thanks, Alipio, for your help.
Message 8 of 19
(5,677 Views)
Congratulations.
Yes, they use to keep last setup for next time.
I was testing more vis (actually I use the analyzer in compatibility mode whit old software) from agesa driver and they run quite fine.
Greetings
Alipio
Message 9 of 19
(5,670 Views)
   I cannot get the E4448A spectrum analyzer to initialize and it is in the proper mode. Are there any option strings that I can put to the initialization string that will ALWAYS force the correct mode, etc so that I can correctly initialize the E4448A? The default initialization string is being used and the E4448A does not want to initialize.
Thanks for any help!
Kaspar
Message 10 of 19
(5,265 Views)
