Agilent GPIB 82350 PCI
I can use the GPIB card of NI to control the Keithley 2400 but I cannot use the Agilent 82350 PCI GPIB to control it.
Do you have the example code to control it?
Please help me.
Thank you very much for your help.
(3,167 Views)
There have been numerous posts on the 82350 and other Agilent controllers that you can look at if you do a search of the forums. One can be found at http://forums.ni.com/ni/board/message?board.id=140&message.id=23403&query.id=53997#M23403. With MAX set up correctly (i.e. tulip support enabled) and the correct drivers installed, your code does not have to change if you are using VISA.
(3,159 Views)
(3,142 Views)
