Agilent/HP E5250A
I am trying to use the driver for the Agilent E5250A to do some measurements with the 4156C Parameter analizer. Does anybody knows how to specify the channel list to the open and close vi's? I know is not supported but I thhought maybe somebody knows how to use this driver.
Thank you
Carlos
(4,005 Views)
Hi Carlos,
From what I can tell, these VIs return a channel list.  Do you want to select the size of the array they return?
Are these functions throwing an error when you use them or do they just not behave as expected?
Jim B
Applications Engineer, National Instruments
-Jim B
CLD, CTD
(3,967 Views)
Hi Jim,
Thank you for your interest. These VIs are supposed to receive the channel list as an input, as it was explained in the user guide. So I guess it does not work as supposed.
Anyways I solved the problem editing the VI such that not only it returns the list but it also receives the list as an input; it is working properly now. I guess the driver was made a long time ago where things were different. (That was Agilent's answer)
Thank you
Carlos
(3,950 Views)
I'm glad you got it to work.  Thanks for the scoop!
-Jim
-Jim B
CLD, CTD
(3,944 Views)
Hi Carlos,
I am working on this project right now. If you dont mind, can you explain to me how you put the input of closechan_list?
(3,779 Views)
Hi Amir,
This was years ago so I don't remember the details, but I went through my backup files and it looks like I used a VISA Write block and input the instructions as a string in my case the instruction was:
:ROUT:OPEN:CARD 3
:ROUT:CLOS:LIST (@30101,30202,30303)
Hope it helps.
(3,758 Views)
Hi amir1428,
This thread is 3 years old, you may have better luck creating a new forum post since I'm not sure if Carlos will respond. Could you explain a little bit more on your question? Thanks!
(3,755 Views)
