Agilent/Keysight E4980A LCR meter driver
Does anyone know of a good plug and play driver for this meter?  I found 2 on the NI website, however, neither one works.  The plug and play driver is broken up into several example vi's that are all missing their sub vi's.  I am looking for a true, user friendly, plug and play style driver that I can use to interface with the meter and display the readings.
(4,692 Views)
Typically NI is pretty careful about the drivers they post. Are you sure you downloaded and installed everything properly? Are the subVIs not there, or are they just not where they are expected?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,689 Views)
None of the VIs are missing from the project style driver. You must not have used Help> Find Instrument Drivers and manually installed it to an incorrect location.
The other is an IVI driver and you are probably missing the compliance package or haven't configured it correctly in MAX if you are trying to use the class driver.
(4,684 Views)
As far as I know I have installed everything correctly.  There is a fluke45 user vi that I downloaded that works (for the most part,)  I can interface and control the fluke from the built in front panel, however, I receive default garbage data returned from the instrument to the front panal display.  I was hoping for the same sort of driver for the E4980A LCR meter.  So it could very well be that I have the sub vi's and they are just not where I expected them to be.
(4,682 Views)
You marked the thread as solved. Why are you continuing to ask questions. You should change that. If you having missing VIs, you need to show exactly where you installed the driver. An image of Windows Explorer will reveal all.
(4,673 Views)
