Agilent Multifunction VT1419A
Has anyone programmed the Agilent Multifunction VT1419A (bought thru VXI Tech) in Labview?  I will be using the SCP card w/ 1533 and 1501 modules.  It will be used for Analog Inputs/Outputs and Digital I/O purposes.  I attempted to inject a voltage on one of the analog channels and read it from the FIFO with NO success.  Any Examples in Labview, is needed, defining and utilizing algorithms, to output data and read the CVT and FIFO.  Thanks, G. Mike
(3,221 Views)
If this is the same card that Agilent used to manufacturer, there is a driver for it at http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=2339.
You might also ahve better luck posting to the dedicated VXI/VME board at http://forums.ni.com/ni/board?board.id=350.
(3,207 Views)
Thanks Dennis.  I did download the driver but I was having trouble getting some of the functions for it to work (i.e. Retrieve FIFO DATA.VI).  I have gotten the CVT data that was present but not data that I am desiring.  Perhaps, some info on the logic needed from input to output and reading the registers.
Thanks for your help.
(3,199 Views)
