Agilent N3301A Electronic Load
I'm looking for examples to use the instrument Drivers for the Agilent N3301A DC Electronic Load preferably in current mode. I do have the Instrument Drivers for this piece of equipment but I'm unable to run it in current mode.
(3,562 Views)
Hi NIrookie,
I'm not sure which version of the instrument drivers you have, but assuming you have at least LabVIEW 8.0, you could use this version "Agilent N330X Series" which includes example VIs. You can get to these examples through the NI Example Finder once you place the downloaded driver folder in your "instr.lib" directory for LabVIEW. Just do a search for "Agilent." You should see an example called "Agilent N330X Series Acquire Measurement.vi". This should be a good starting point.
Asa Kirby
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(3,540 Views)
Hi there, I have no experience yet in electronic load operation, but I just want to know if Agilent N3305A (150 Vdc, 60 A) can be connected in series? Because I have this requirements, 397 Vdc , 40 A. Could someone help me on this. thank you
(3,126 Views)
