Agilent multimeter Library
I dragged the folder as you suggested, but the path stayed to be related to "Program Files" (attached).
Thanks a lot, again.
Message 11 of 14
(1,286 Views)
Message 12 of 14
(1,286 Views)
Yes. We have included the library from that folder path only.
If you want to copy the Agilent library folder to your project folder and want to replace all the VIs from that folder, Just copy the folder to your project folder and delete the folder from instr.lib path. Restart LabVIEW and open the project file, now labVIEW will ask for the library path. So you can just choose it from the new folder you have created in your project folder.
Message 13 of 14
(1,278 Views)
I'll try this trick too.
Thank you very much for your help!
Message 14 of 14
(1,265 Views)
