Agilent n6700
I'm trying to measure a large I-V array in AG N6705A.
I've installed the drivers, and got it to work with ~4000 measurements, through the "Measure Array.vi".
The problem: if I try any more than 4000 points, the vi hangs and I get a -410,"Query INTERRUPTED" error.
Should I be using the data logger instead? I couldn't find how to import the measured array into LV.
(2,878 Views)
oh silly me...
the byte read count was set to 60,000 (default in the IVI driver)
increasing it to 300,000 solved the problem.
Thank you!
(2,873 Views)
