Aide assistance daq
Bonjour, est-il possible d'utiliser deux assistant daq dans le même vi, parceque quand j'essaye de le faire lors de l'execution je recois un message d'erreur qui dit "La ressource spécifiée est réservée. L'opération n'a pas pu se faire comme spécifié."merci d'avance.
(3,678 Views)
In general, yes you can. Except (as you discovered) they can't be accessing the same resource. For example, they both can't be trying to read different analog channels from the same board.
If the two DAQ Assistants are trying to access the same resource there probably doesn't need to be two. Reconfigure one of the Assistants to read all the required channels, and delete the other one.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,664 Views)
Thanks for your answer, So if I understand well you can not acquire and generate the same time from a single card acquisition.
(3,658 Views)
You can acquire and generate from the same card, but perhaps not with the DAQ Assistant interface. Check the DAQ examples.
Mike...
LabVIEW Champion
(3,655 Views)
Hi O.,
you can acquire and generate at the same time with your DAQ board - have each in its own DAQmx task…
Did you check the example VIs coming with your LabVIEW&DAQmx installation?
(3,654 Views)
Is it possible to have an example of VI (I have version labview 2013) thank you in advance
(3,639 Views)
In LabVIEW: Help->Find Examples.  You should be able to easily find examples on performing an analog input and analog output, just not likely together in the same example.  But you can put the concepts together to have both Analog Input and Analog Output happening at the same time.
(3,636 Views)
