Aktive Pinbelegung des NI 6212 anzeigen lassen
Hallo,
Ich suche eine Option wie ich dei aktive Pinbelegung des NI Moduls sehe. Quasi wie das Datenblatt was man sieht wenn man auf Pinbelegung des geraets geht nur als Live anzeige welcher pin belegt ist und welcher nicht. Ich hatte mal sowas gesehen aber finde es nicht wieder. Hoffe ihr wisst was ich meine LG Julius
Message 1 of 8
(1,165 Views)
Hi Julius,
keep in mind this is the worldwide LabVIEW board, so you better write your messages in English!
Do you want to see the same as in MAX when you configure a task?
When you build your DAQmx task in your VI then you should know which terminals of the DAQ device are used: you could build your own display with an image of the connector of your DAQ board and some boolean indicators on each pin to show its status...
Message 2 of 8
(1,148 Views)
Hello, Thanks for the answer. I know that i could build it like that and i also know which ports are used and which dont. But i thought there was an Illustration of the active pins in NI max and i dont find it anymore...
Message 3 of 8
(1,135 Views)
Hi Julius,
As I wrote before you get an illustration in MAX when you configure a task...
Message 4 of 8
(1,128 Views)
If i create a task in Max this is the only thing which shows up...
Message 5 of 8
(1,121 Views)
Accepted by topic author Julsbng
Hi Julius,
once you created the task you can see its connection scheme:
Message 6 of 8
(1,113 Views)
Thank you very much! Is there a ovrview as well of all tasks or ist there only one for every single task?
Message 7 of 8
(1,109 Views)
Hi Julius,
MAX only shows you how to connect wires for the selected channel within your task…
Message 8 of 8
(1,062 Views)
