Align objects to a first object without the first object moving
I have several objects on a front panel that I want to align with one another.  One object should keep its original position and the others should be aligned to it.  Is there a way to do this?  The normal method of alignment seems to move all the objects, including the one that I want to retain its original position.  I tried locking the object that isn't supposed to move, but then I can't seem to align to it anymore.
Darin
(5,222 Views)
If you want to align them to a side (top, bottom, left, right), make sure the base object is the outermost in that direction.
For center alignment I don't think such a feature is available.
Ton
My LabVIEW Ideas
(5,219 Views)
Any subscribers to this thread, please kudo Matthew's idea to fix this misbehavior 🙂
LabVIEW Idea Exchange: Rework front panel object alignment
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Rework-front-panel-object-alignment/idi-p/978988
(5,008 Views)
