Aligning a Waveform with its post filtered self
How do you align a waveform with its filtered waveform after you filter it?  I need to create an upper and lower limit using a filtered version of a waveform and then use the resulting limits to test it.
(2,718 Views)
To align a waveform with its filtered version you can use the "Align two Waveforms" case of the "Align Waveforms (continuous) VI".
Mikhail
RF Toolkits, Product Support Engineer
(2,695 Views)
thanks but that is what I was using in the attachment I posted and it deosnt seem to work as advertised.  Am I doing something wrong in the express VI settings?
(2,686 Views)
What behavior are you observing when you say it does not work as advertised?
Also, the function that Mikhail is different than the one you are using.  There is an example listed for this function on your computer in this location labview\examples\measure\resample_align_xmpl.llb
Ryan
(2,671 Views)
