Aligning data sets not created with waveforms
I'm creating a tracking test where the user follows a computer generated line on a touch screen. How can I align and resample these two sets of data (each set is an array of time, X, and Y coordinates)?
(3,104 Views)
I am afraid I don't fully understand the setup or the issue here. What do you mean by "the user follows a computer generated line on a touch screen?" Do you mean that the user actually touches the screen and tries to follow a line on the screen with his finger? If this is the case, what are you trying to plot?
Please write back with more details.
Khalid
(3,102 Views)
Yes, that is exactly right. What I want to do is line up the coordinates of the line and the touch for each time so that I can calculate error. I'd then like to sample this data at a given rate so that the data file doesn't get too big.
Thanks for your help!
(3,102 Views)
I now understand what you're trying to do. You basically have to take the difference between the Y values for the two plots (the computer-generated one, and the touch-generated), for each value of X. X, in-fact will be the same for both the plots as you want to compare at a given time.
You can plot the resulting difference as the Y values against the same X values.
I have attached a screenshot showing this. Hope this gives you some ideas.
Khalid
(3,104 Views)
