07-25-2011 04:40 AM
In order to change the I/O variable data type of my node from single to array of single, I simply press and hold the rest button on WSN-3202 for 7seconds. At the end of it, the radio signal LEDs went off and node went dead. All attempt to bring it back to life proof abortive. What should I do?
Blessing
08-02-2011 11:12 AM
Hi Blessing,
If you've tried everything to get it working, including a fresh set of batteries or direct power from an adaptor, then you should contact your local NI branch regarding the repair process. The contact information for your branch can be found on http://sine.ni.com/apps/utf8/nicc.call_me.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
