Allan variance and bias stability measurement?
Hello every one,
I would like to do some measurement on  MEMS microaccelerometers. They provide analog output voltage and are interface with a data acquisition board through the analog input channel.
Does any one know if there are predefined programs (routines) in LabView to measure the bias stability and plot the Allan Variance of the measured data?
Thanks.
BVA
(4,552 Views)
I recall a question about Allan Variance being posted some time ago, although I do not recall whether any solutions were found. Have you searched the archives?
Lynn
(4,545 Views)
Hey Lynn,
Thanks for the info.
I actually searched through the "advanced search" and didn't see any message for the Allan Variance measurement. This is the way to search the archives, isn't it?
BVA
(4,536 Views)
Hello BVA,
I don’t believe there are any built in functions to do what you are looking for. However, it looks like a third party source has posted some code that will compute the Allan Variance for you.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=EF32F4D54B4A211CE0340003BA230ECF&p_...
It might give you a good start. Best of luck!
Chris J
(4,528 Views)
Thank you very much, Chriss.
It will definitely help me alot!
Regards.
BVA
(4,522 Views)
Why does a search of the entire NI site not turn up this link??
(4,514 Views)
It came up as the 2nd hit when searched on ALLAN within the entire site
(4,506 Views)
