Allen Bradley driver
    I have not until now had the chance to create a driver for a PLC.  I know little about the PLC architecture but what I have read on the web.  I would first like to know is the driver interface similar to 488 protocol.  Do I simply write "string tags" to an IP address over the Ethernet.  Or do I need another tool to add to my labview to provide me with short cuts to be able to write a driver for the Allen Barley 5370 PLC in LV2011.
    I have written many drivers before through serial and 488 but, this is my first PLC.  I am sure that once I get a chance to start on the interface it will make sense but now I am uncertain how to start.  If the instrument I/O are string commands then it would seem straight forward.  However I would need your experience and input for the best way to proceed to write the driver and what to look out for and to plan for.
Regards Dwight Duncan
(4,143 Views)
Accepted by topic author teslac
I have not personally developed a driver for a PLC in LabVIEW from scratch, but I am familiar with interfacing with PLC's via LabVIEW. If you looking to develop code in LabVIEW that communicates with the AB 5370 PLC then I would highly recommend exploring the EtherNet/IP toolkit for LabVIEW. It provides both implicit and explicit messaging to send and receive data from a PLC. It also comes with several starter examples to illustrate how to implement the functions properly. I hope that this is somewhat helpful!
dK
(4,090 Views)
RE:  Thanks for you input.
(4,085 Views)
I wrote one a while back in a different language (Testpoint) and used the AB DF1 protocol manual to figure out how.
Here's a link to the manual for the DF1 protocol...
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1770-rm516_-en-p.pdf
Here's a link to one on the NI community.  I looked at it a while ago and it will probably take some tweeking...
https://forums.ni.com/t5/Example-Code/DF1-driver/ta-p/3513101
Good luck,
Mike
(4,074 Views)
