02-16-2005 06:40 AM
02-17-2005
04:56 PM
- last edited on
09-23-2025
10:32 AM
by
Content Cleaner
Hello Josh,
Thank you for contacting National Instruments. IMAQ create returns a reference to the location in memory where the image will be stored, refer to the IMAQ Vision Concepts Manual for more information about how image data is stored in memory. The memory is allocated for an image when you actually specify the size of the image to be stored at that memory location or acquire an image into the buffer. You can run out of memory quickly if you call imaq create inside a loop providing a different name for each buffer and allocating memory for each image. To clear out all memory allocated for images you can call IMAQ dispose and wire a true to the "All Images?" input. I hope this helps you out.
Nipun M
