Almost there...but I have an error!
I know I have posted similar programs before, but I took the while loop out of digital.vi and made a couple other changes. When I run voltagecontrol.vi, and press the stop button to move beyond the while loop, an erro pops up and it tells me that I need to either increase the amount of time before it times out or increase the sampling rate. The error occurs at the DAQmx Write.vi in digital.vi. I tried using the timing control in DAQmx, but it wasn't working (as well as trying a number of other things to fix the problem. After the error occurs, I press continue, and what I want to happen does. (as opposed to before! So it's a good start) But I would like to be able to press the "stop" button on voltage control.vi, and move right on to the next digital output, without that wait time involve. What do I need to fix in my program(s)??
Thanks for any help!
Bethany
Message 1 of 10
(3,893 Views)
Hi bethany,
Post ur VI as a development distribution, go to save with options and select development distribution to save as a library file.
all ur sub VI's are missing.
Its not clear if u are dong any data acquisition in ur sub VI's
Message 2 of 10
(3,885 Views)
Hi Bethany,
      The error you describe implies a multi-sample-write is being attempted in digital2.vi.  What's wired to DAQ mx Write\"data" in digital2.vi?
D.
When they give imbeciles handicap-parking, I won't have so far to walk!
Message 3 of 10
(3,865 Views)
It is the exact same thing as digital.vi that was attached - I just was trying to put it into a different vi earlier to see if that was the problem.  Can you see a problem with the wiring in digital.vi??
Thanks for your help!
Bethany
Message 4 of 10
(3,860 Views)
Hi Bethany,
      I don't see anything wrong, but I haven't used DAQmx much (yet. 🙂 )
The attached code implements the original "voltagecontrol" logic, but using a single reference to digital.vi.
If this doesn't work, perhaps you can share the error code?
BTW, It uses an event-structure to trigger loop on control updates!
cheers
Message Edited by Dynamik on 11-12-2005 09:24 PM
Message 5 of 10
(3,853 Views)
Thanks Dynamik,
It does work well (it does not pause as it did with my rendering, and it works well in all regards! Finally!), although it still shows error code -50103 at the end... (the same error that was showing up for me previously) Is that a problem?
Bethany
Message 6 of 10
(3,818 Views)
Hi Bethany,
      Sorry, I can't run your code to reproduce the error (no hardware.)  I do recommend you determine the source of the error, but I'm not a good resource for DAQmx.  I notice that DAQ Assistant returns a task ID.  Perhaps that task should "cleared" before a subsequent call to DAQ Assistant.
Wish I could be more help!
Message Edited by Dynamik on 11-15-2005 03:19 PM
Message 7 of 10
(3,799 Views)
Hello Bethany,
The 50103 Error indicates that you are trying to use a resource on the board that is already being used.  This article has a good description of what is going on.  This error is a problem because it means that your Task will not be able to be executed due to the reserved resources.
I hope this helps!
Eric
DE For Life!
Message 8 of 10
(3,772 Views)
There is one thing wrong with that article, however.  It assumes that when you run independent channels that you will be sampling each channel at the same rate.  I tried to incorporate several channels into the same task, but when I try to configure each channel it makes these changes to ALL of the channels in my task?  How do you get around this?  I need to sample each channel at different rates, plus on some channels I want to use triggering and on others I don't.  No what?
Message 9 of 10
(3,689 Views)
jwhite,
As explained in the article (and in another thread), you cannot sample different channels of the same multiplexed device at different rates.  This is not a limitation of LabView, but rather a limitation of the electronics.  Multiplexers are not bad things.  They allow us to sample dozens of channels using just one A/D device, thus saving us a lot of money.
Message Edited by jasonhill on 02-14-2006 03:21 PM
Message 10 of 10
(3,669 Views)
